Likes Likes:  5
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Juiced Cafe Racer Battery Swap
    1,962
    Phase one of the battery swap has commenced!!!
    After some research and good advice from my friends here the swap is on!
    The Volt battery packs have been ordered (2 - 48V 45AH packs) and will be here Thursday.
    The old battery boxes and cables have been pulled and weighed. A whopping 148 lbs! The original
    ICE to EV conversion still made the bike 160 lbs less than the original ICE setup. Now we are
    looking at another 50+ loss. The rest of the this weekend will be spent inspection the bike and
    touching up any paint issues etc.
    Photos as I go will be posted.
    Later!
    1,794
    Excited to see this. I know must guys are using Leaf cells, but I have seen volt packs used in an el moto yet. I think they offer some interesting advantages if you can utilize the packaging size/configuration. So you will be using two 12s modules?
    1,962
    Yes, 2 - 12s. I think the weight loss on the bike should make up for the smaller amount of AH compared to the LEAF cells. (Still more than I currently have)
    We will see. This is a older 79 frame so fitting the leaf cells would have been a chore.
    I work 9 miles from the house so either way I should be able to ride hard and still have plenty when I get home.
    1,962
    The Cafe bike is up and running in a Beta test mode. I took it around the block this morning and the 52lb weight loss
    made a big difference in acceleration and handling. The acceleration was better, as expected, but the CG
    difference was more pronounced than I expected. It was good, but when you lose that much from the bike it is
    MUCH easier to lean into the turn..
    The voltage drop was minimal, but I have not "twisted it up" just yet.
    More later!!
    Ed
    (Note: The cable ties are not holding the controller on, they are holding the cables up
    underneath from rubbing the battery pack.)
    687
    If they're anything like the Leaf cells, just bulk charge to 4.1 per cell and only pull ~80% of the AH's out'a them (avoid the cliffs). They STAY within .025 volts of each other. *This data based on ~25 cycles.
    1,962
    Charged the batteries to 4V and took the Cafe racer out again today. It accelerated quickly and was only at a max of 128 amps thoughout the ride.
    Did 4.3 miles at 4.8 AH. A little higher than I normally see, but I was running at 60 MPH.
    I did check the weight of the Bike without me on it. 154 lb on the front and 178lb on the back. 332lbs on a bike that was 564 pounds when it was an ICE ride. This is a net loss of 48lb from the old battery pack.
    I had to add some brackets, but still have about 2 pounds of cabling and other brackets to remove (Never cut anything off until you are done testing!).
    More later!
    975
    Cool... so have you decided to call it a Hondvy or a Chevda?
    687
    Makes sense, you have a higher pack voltage before correct? Same WH with less V you're going to use more I !
    How did it feel? Stiffer than the headways (less sag)?
    1,962
    Less sag, but I would expect that with the lighter bike.
    I will know more when I get a longer ride on it. (lots of thunder storms lately.)
    687
    Mine is like 8 volts less sag between the Leafs and Calbs. The Calb's were only 40ah however....Leafs 62ah.
