Flo I wasn't sure if I should just direct message you, but maybe some other newbies will find this interesting as well.
Is there a specific set of benefits to using the Cycle Analyst with a Kelly over a display like a Ct-22 (that are typically sold in kits to use with the model of Kelly controller you use)? From what I understand the negatives of a Ct-22 is that it really is only a display of overall voltage and speed. And does not monitor Amp draw, so I would need a separate system with my battery if I wanted to more closely monitor battery status.
Obviously the CA is capable of monitoring a lot more than just Speed and Voltage. From my understanding of things, the main benefits of a CA are that along with speed, voltage, etc. it also can monitor amps in and out of your battery (instead of needing to use a separate system to achieve this).
I'm wiring up a QS 273 70H and a Kelly KLS72601 - similar to you but a hub motor instead of mid drive.
And I'm just assessing the main benefits of running the Cycle Analyst either alongside a display like the ct-22 or completely instead of. Thanks for your time, and experience. Others on Elmoto have already been super helpful. Sorry If this isn't forum etiquette and I'm hijacking your build thread, I'm just really impressed with your builds so far.
