Results 1 to 1 of 1
Thread: LED tallight solution
    Aaron Lephart
    Just a repost since the new forum software came about!
    I am SLOWLY doing this mod because of other things I have going on. It it a LED PCB board out of a 2002 CBR 600RR that uses the superior surface mount LED's. They are clear but light up red. This is better because filtering the light to "make" red loses some of the brightness. I have to still get a clear taillight lens from a friend and empty socket bases to solder in the LED wires without as to make this easily reversible if its not what I want.
    All the best,
    Aaron Lephart
